Index Match How to avoid blank cells
lwilt
I'm trying to use an index match and the column where I'm trying to return data has blank cells in it. The formula I tried but didn't work was:
=INDEX(F2:F2000,IF(F2:F2000<>"",MATCH,A1,A2:A2000,0)))
The problem I'm running into is that the data I'm trying to return on an entry occurs after a blank and that entire entry is skipped. Below is an example so you can see what's causing my issue.
order A return data
order A blank
order B blank
order B return data
order B return data
So order A will allow to me return the information I'm trying to grab for that order but on B because it's first cell is blank all of order B is skipped and I can't return that piece of data I'm trying to get.
thanks for the help.
Try this :
=INDEX($F$2:$F$2000, SMALL(IF($A$2:$A$2000 = $A$1, IF($F$2:$F$2000 <> "", ROW($A$2:$A$2000) - MIN(ROW($A$2:$A$2000)) + 1)), ROWS($A$1:$A1)))
This is an array formula , to be entered using the key combination of CTRL SHIFT ENTER.
I attached a sample workbook.
I will give that a try Narayan
  • index match ex file.xlsx
Maybe,
In I2, formula copy down :
=IF(COUNTIFS(Sheet2!A:A,C2,Sheet2!F:F,"Custom")>0,"Custom","")
or,
=IF(COUNTIFS(Sheet2!A:A,C2,Sheet2!F:F,"><")>0,"Custom","")
Bosco
