Harry Covair
Hi the forum,
I want to submit the forum the following problem:
In a VBA procedure, I feed an array variable (Dim Temp_Max () As Variant, ReDim Temp_Max(200)) with temperatures (numeric values):
Same reasoning with years
In each case, debug.print shows the correct values.
As the SetSourceData method requires a range, and cannot use a Variant array, I have to use the individual components of the Series objects.
How to use these arrays in a chart?
I tried
But on “.Chart.SeriesCollection(1).XValues = Temps_Max”, it generates an error message “Application-defined or object-defined error”.
The final result should be something like:
I would really appreciate could some member of the forum help me.
Thank you in advance for your answer.
Harry
the_temps_Max(i_temp) = Worksheets("DATA").Cells(x, 4).Value
the_years(i_temp) = Year(Worksheets("DATA").Cells(x, 2))
I tried
Dim mychart As Object, Min_chart As Single, Max_chart As Single
Min_chart = WorksheetFunction.Min(the_temps_Max)
Max_chart = WorksheetFunction.Max(the_temps_Max)
Set mychart = ActiveSheet.ChartObjects.Add(Left:=300, Width:=300, Top:=10, Height:=300)
With mychart
.Chart.Type = xlLine
.Chart.SeriesCollection(1).xlValues = the_temps_Max' ERROR MESSAGE
.Chart.SeriesCollection(1).XValues = the_years
.Chart.HasLegend = False
.Chart.Axes(xlValue, xlPrimary).MaximumScale = Max_chart
.Chart.Axes(xlValue, xlPrimary).MinimumScale = Min_chart
.Chart.SeriesCollection(1).Trendlines.Add
Harry
