michelleponan
Dear Everyone,
I need your help. How can I change the code if I want the data to be pasted on the 4th row of every sheets instead of 2nd row? Please find the below code.
Thank you.
Michelle
Sub parse_data()
Dim lr As Long
Dim ws As Worksheet
Dim vcol, i As Integer
Dim icol As Long
Dim myarr As Variant
Dim title As String
Dim titlerow As Integer
vcol = 5
Set ws = Sheets("Sheet Piles Summary")
lr = ws.Cells(ws.Rows.Count, vcol).End(xlUp).Row
title = "A1:E3"
titlerow = ws.Range(title).Cells(1).Row
icol = ws.Columns.Count
ws.Cells(1, icol) = "Unique"
For i = 2 To lr
If ws.Cells(i, vcol) <> "" And Application.WorksheetFunction.Match(ws.Cells(i, vcol), ws.Columns(icol), 0) = 0 Then
ws.Cells(ws.Rows.Count, icol).End(xlUp).Offset(1) = ws.Cells(i, vcol)
myarr = Application.WorksheetFunction.Transpose(ws.Columns(icol).SpecialCells(xlCellTypeConstants))
ws.Columns(icol).Clear
For i = 2 To UBound(myarr)
ws.Range(title).AutoFilter field:=vcol, Criteria1:=myarr(i) & ""
If Not Evaluate("=ISREF('" & myarr(i) & "'!A1)") Then
Sheets.Add(after:=Worksheets(Worksheets.Count)).Name = myarr(i) & ""
Sheets(myarr(i) & "").Move after:=Worksheets(Worksheets.Count)
ws.Range("A" & titlerow & ":A" & lr).EntireRow.Copy Sheets(myarr(i) & "").Range("A1")
Sheets(myarr(i) & "").Columns.AutoFit
ws.AutoFilterMode = False
ws.Activate
Thank you.
Michelle
Sub parse_data()
Dim lr As Long
Dim ws As Worksheet
Dim icol As Long
Dim title As String
vcol = 5
title = "A1:E3"
For i = 2 To lr
ws.Activate
