How to increase the speed of the macro.
Jagdev Singh
Hi Experts.
I am currently using the below code to create a pivot table and the amount of entries in the RAW data is around 95k. I am happy with the outcome, but the only issue is with the amount of time it takes for the macro to run and reflect the output. I measure the time and it takes more than 5 mins to complete the task.
Is there a way we can reduce this time.
Sub CreatePivotTable()
Dim PvtTbl As PivotTable
Dim wsData As Worksheet
Dim pivotrng As Range
Dim lrow As Long, lCol As Long
Dim wsPvtTbl As Worksheet
'Worksheet which contains the source data
Set wsData = Worksheets("Data")
'Worksheet where the new PivotTable will be created
Set wsPvtTbl = Worksheets("Pivot")
'delete all existing Pivot Tables in the worksheet
'in the TableRange1 property, page fields are excluded; to select the entire PivotTable report, including the page fields, use the TableRange2 property.
For Each PvtTbl In wsPvtTbl.PivotTables
If MsgBox("Delete existing PivotTable!", vbYesNo) = vbYes Then
PvtTbl.TableRange2.Clear
Next PvtTbl
LastRow = Cells(Rows.Count, 1).End(xlUp).Row
LastCol = Cells(1, Columns.Count).End(xlToLeft).Column
ActiveWorkbook.PivotCaches.Create(SourceType:=xlDatabase, SourceData:= _
"Data!R1C1:R" & LastRow & "C" & LastCol, Version:=xlPivotTableVersion14).CreatePivotTable _
TableDestination:="Pivot!R6C1", TableName:="PivotTable1", DefaultVersion _
Sheets("Pivot").Select
Cells(3, 1).Select
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Organisation name")
.Orientation = xlRowField
.Position = 1
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Created Date")
.Position = 2
With ActiveSheet.PivotTables("PivotTable1").PivotFields("UWSettDueDate")
.Position = 3
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Posting Ref")
.Position = 4
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Insured")
.Position = 5
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Business Unit")
.Position = 6
With ActiveSheet.PivotTables("PivotTable1").PivotFields("PrioritySettType")
.Position = 7
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Internal Notes")
.Position = 8
ActiveSheet.PivotTables("PivotTable1").AddDataField ActiveSheet.PivotTables( _
"PivotTable1").PivotFields("Ledger Amount GBP"), "Sum of Ledger Amount GBP", _
xlSum
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Assigned Handler")
.Orientation = xlPageField
.Position = 1
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Transaction Type")
.Position = 1
With ActiveSheet.PivotTables("PivotTable1").PivotFields("AgeBandBasedNextMonthEndDate")
.Position = 1
With ActiveSheet.PivotTables("PivotTable1").PivotFields("LedgerTransBreakdownStatus")
.Position = 1
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Within 60 days?")
.Position = 1
.InGridDropZones = True
.RowAxisLayout xlTabularRow
ActiveWorkbook.ShowPivotTableFieldList = False
ActiveSheet.PivotTables("PivotTable1").PivotFields("Organisation name"). _
Subtotals = Array(False, False, False, False, False, False, False, False, False, False, _
False, False)
ActiveSheet.PivotTables("PivotTable1").PivotFields("Created Date").Subtotals = _
Array(False, False, False, False, False, False, False, False, False, False, False, False)
ActiveSheet.PivotTables("PivotTable1").PivotFields("UWSettDueDate").Subtotals _
= Array(False, False, False, False, False, False, False, False, False, False, False, False _
ActiveSheet.PivotTables("PivotTable1").PivotFields("Posting Ref").Subtotals = _
ActiveSheet.PivotTables("PivotTable1").PivotFields("Insured").Subtotals = Array _
ActiveSheet.PivotTables("PivotTable1").PivotFields("PrioritySettType"). _
False, False)
ActiveSheet.PivotTables("PivotTable1").PivotFields("Internal Notes").Subtotals _
ActiveSheet.PivotTables("PivotTable1").PivotFields("Business Unit").Subtotals _
ActiveWindow.Zoom = 90
Columns("A:A").ColumnWidth = 30
Columns("D:D").ColumnWidth = 23.29
Columns("E:E").ColumnWidth = 20.86
Columns("F:F").ColumnWidth = 19.43
Columns("G:G").ColumnWidth = 30
Columns("H:H").ColumnWidth = 30
ActiveSheet.PivotTables("PivotTable1").PivotSelect "'Internal Notes'[All]", _
xlLabelOnly, True
Range("D7").Select
Columns("H:H").Select
Selection.Style = "Comma"
Columns("I:I").Select
Before you make any changes to the PivotTable, do this:
ActiveSheet.PivotTables("PivotTable1").ManualUpdate = TRUE
...and then after you've made all the changes, do this:
ActiveSheet.PivotTables("PivotTable1").ManualUpdate = FALSE
That will stop the PivotTable recalculating every time you make a change to it. That should dramatically reduce the time it takes this code to execute.
Also, instead of using this all the time:
...do something like this:
with .PivotFields("Organisation name")
'code here
end with
with .PivotFields("Created Date")
'code here
end with
with .PivotFields(....)
'code here
end with
