How to get numbers in a column to be classified in a range using formula
vijitkumar
In column "A" I have numbers.
In column "B" and "C" I have specified the desired outputs.
Please let me know how to achieve this.
I tried with IF condition using AND but it is not working and throwing error.
  • Classify numbers in a range.xlsx
Formula for col B:
=ROUNDDOWN(A2,-2)+1&" - "&ROUNDUP(A2,-2)
For col C, how do we know which range is oldest/older/old? Is it always the 501-600 group that is oldest, or is it because it's the largest in value?
Just another approach for column B. See the file. For column C I am also confused.
It is either column B or column C that I needed the output as.
IN column c, I wanted to get an output with a custom text that specify
For eg: if the number is between 501 and 600 in a cell in column A, the output should be "oldest" or for that matter any text I specify.
In that case, I'd setup a lookup table (say in range D1:E5) with 1 column being the ranges, and the other being desired output, like:
101-200
201-300
301-400 Old
401-500 Older
501-600 Oldest
Then, formula in col C is:
=LOOKUP(B2,$D$1:$E$5)
