How to get 50 unique random values from 1 to 150
Dear friends:
I have 150 questions in my database in a separate excel sheet.
I want 50 random questions out of those 150 questions each time a user opens the excel file.
Thank u.
Hi James,​
this is a fast unique random values function, check it by launching Demo on a new workbook :​
Function ArrayRandom(Number%, Lower%, Upper%) As Integer()
         ReDim AR%(1 To Number)
         Randomize
         C% = Upper - Lower + 1
         For N% = 1 To Number
             Do
                 R% = Lower + C * Rnd
                  V = Application.Match(R, AR, 0)
             Loop Until IsError(V)
             AR(N) = R
         ArrayRandom = AR
         Erase AR
End Function
Sub Demo()
    Dim UV%()
                UV = ArrayRandom(50, 1, 150)
    [B1:B50].Value = Application.Transpose(UV)
    Erase UV
Enjoy !​
If you need to sort the column, launch SortDemo on a test workbook :​
Function UniqueValues(Number%, Lower%, Upper%) As Integer()
        Randomize
            Do
            Loop Until IsError(Application.Match(R, AR, 0))
            AR(N) = R
        UniqueValues = AR
        Erase AR
End Function
Sub SortDemo()
    [B1:B50].Value = Application.Transpose(UniqueValues(50, 1, 150))
    [B1:B50].Value = Application.Transpose(Evaluate("TRANSPOSE(SMALL(B1:B50,ROW(1:50)))"))
In SortDemo procedure, the first code line loads the array into the range.​
The second line sorts the range through maybe the most powerful VBA instruction : Evaluate …​
