Hi Hakim
It is quite refreshing to see a form laid out well. You have thought about the order of your text boxes in line with the data in your database. Well done. I don’t often see this clear logic.
I have changed a bit in your form. You appear to be wanting the Edit procedure to fire after EditStudent1 has been changed. If you hit the edit button type 125 and hit ENTER.
You will see the form now auto populates. Here is the code.
Private Sub editstudent1_KeyDown(ByVal KeyCode As MSForms.ReturnInteger, ByVal Shift As Integer)
If KeyCode = vbKeyReturn Then
Findit
Private Sub Findit() 'Find and populate the records
Dim fnd As Range
Dim Search As String
Dim sh As Worksheet
Dim i As Integer
Set sh = Sheet2
Search = editstudent1.Text
Set fnd = sh.Columns("A:A").Find(Search, , , xlWhole)
If fnd Is Nothing Then
MsgBox "No Student Found", , "Error"
editstudent1.Text = Null
For i = 2 To 13
frmeditrecord.Controls("editstudent" & i).Text = sh.Cells(fnd.Row, i).Value
Now if you change something in the form and hit UPDATE. You will see this change reflected in the Details tab.
I think this is what you were looking for.
I would use the changes I have made to your coding and update the rest of your procedures to reflect this. I only updated the EDIT form.
File attached to show workings.
Take care
Smallman
