Why use the mouse? Use the keyboard instead. Go to the nearest column that has continuous data. Use the Ctrl+ArrowDown to get to the bottom. Move over to where the new formula needs to be. Anchor the point by holding down the shift key and then Ctrl+ArrowUP. Ctrl+D to copy down and you are done.
