Samadhan Gaikwad
I wanted to hit button on web page so that second web page will be loaded and I can save the whole source code of that web page. Right what I have is:
And web page source code for button is:
Sub SaveHTML()
Dim str, URL As String
Dim IE, frm As Object
Dim i As Long
Dim FileName As String
Dim FF As Integer
Dim elems As IHTMLInputTextElement
Dim wb As WebBrowser
Dim objElement As Object
Dim objCollection As Object
str = Sheets("Sheet1").Range("J1").Value
URL = "https://tiweb.industrysoftware.automation.siemens.com/prdata/cgi-bin/n_prdata_index.cgi" 'for TEST
FileName = "C:\Users\a3rgcw\Downloads\7946412\7946412\Test.htm"
Set IE = CreateObject("Internetexplorer.Application")
IE.Visible = True
IE.Navigate URL
Do
Loop While IE.Busy
IE.Document.getElementsByName("pr_numbers")(0).Value = str
Application.SendKeys ("~")
' Need button click code here
CreateObject("Scripting.FileSystemObject").Createtextfile FileName
FF = FreeFile
Open FileName For Output As #FF
With IE.Document.body
Print #FF, .outerHTML & .innerHTML
Close #FF
IE.Quit
Set IE = Nothing
<td style="border:solid 1px #060; border-left: none">
<textarea name="pr_numbers" rows="5" cols="22" >
</textarea>
<br>
<button onClick="return check_mvsub(this)">
<br>
<b>
Search and Download
</b>
<br>
</button>
</td>
</tr>
