Beginner excel user here and I'm trying to create a few simple macros for work. They work ok, except that once used I end up with the same cell (H19 in the example below)highlighted after each use.
How do I program/edit the macro so the highlighted cell is always the cell below where I just used he macro? (So if I used the macro in cell C7, the highlighted cell would be C8, rather than jumping to H19 every time)
Sub refused()
' refused Macro
' refused
' Keyboard Shortcut: Ctrl+Shift+I
With Selection.Font
.Color = -13408666
.TintAndShade = 0
ActiveCell.FormulaR1C1 = "refused"
Range("H19").Select
