Hello Folks,
Hope somebody help here.
Please check the attached file, which ever files as per the values in columns F to M are present in folder1 should be zipped and encrypted as per the value in column N and stored in folder2, missing files should be ignored.
The code works fine for single file, is it possible to zip multiple files?
