Formula for Conditional Formatting
Shazz
Can anyone tell me what Formula I would need to do the below.
Cell A1 has ULKY5010 then G1 shows Joe Bloggs.
Basically I have a list of 6 names and various Project Numbers, depending what Project Number is shown in A4 will depend what name is shown in G4, or would a lookup be better.
Please see attached.
Can anyone help at all?
Shazz
x
  • Example.xlsm
I couldn't find "Joe Bloggs", but a lookup will work... to use VLOOKUP you will need to rearrange the lookup table/matrix, since VLOOKUP requires the searched value to be on the left most column of the lookup matrix.
Similarly to a VLOOKUP, you can use INDEX/MATCH as in the attachment.
Hope this helps
  • Example.xlsm
Thanks for that, that worked great, is there any way the VLookup can be altered so that if a project code appears and is is not in the approvers list that it will automatically show as Sarah??
  • Example (1).xlsm
Don't mention it :)
Sure, you can use IFERROR (see attached)
  • Example (1).xlsm
