Confusion between Static variables & Constant variables.
Hi All,
I am a learner in VBA, and confused in between static variables and constant varialbes.
Also which one is default. If would be great if explained with example.
Thanks in advance
Hi Gaurav ,
First , there is nothing like a constant variable. There are constants , and there are variables.
Constants are entities that cannot be changed within the code ; they are declared once , using a statement such as :
Const UPPERLIMIT = 32
The entity named UPPERLIMIT now has the value of 32 , and it will retain this value for the lifetime of the code execution ; any attempt to assign a different value to this entity , such as :
UPPERLIMIT = 5
will generate an error.
Constants assume the type that their assigned value gives them ; thus in the above example , UPPERLIMIT will be of type Integer ; if the declaration of the following entity MAXROWS is :
Const MAXROWS = 1048576
then MAXROWS will be of type Long.
More information is available here :
http://msdn.microsoft.com/en-us/library/x2a031a0.aspx
Variables are entities that can be changed within the code ; they are declared once , using a statement such as :
Dim just_another_variable As Integer
Following the above declaration , the entity named just_another_variable will have the default value of 0 , and it will retain this value till another statement within the code assigns a different value to this entity , such as :
just_another_variable = 5
Thus variables need to be declared , and thereafter assigned values within the code.
Static variables are those which are declared using the keyword Static , as in :
Static yet_another_variable as Integer
An example of how this is used , is given here :
http://msdn.microsoft.com/en-in/library/z2cty7t8.aspx
You can also declare the Constant type during definition
eg:
Const MyInt As Integer = 5
Const MyInt2 As Long = 5
I would go one step further and suggest that one should explicitly define the constant's data type.
  • Constants' values cannot be changed at runtime.
  • Variables' values can be changed at runtime. Static variables are procedure level variables which retain their values between procedure calls.
