Jack-P-Winner
already answered
Hi Larry ,
Which means that you do not want either the C2 or the C101 to change as you drag down ?
If that is so , the first change you should make is use the $ sign before the row component , as in :
=COUNTIF(link!C$2:C$101,1)
This ensures that as you drag / copy this formula downwards , irrespective of where you may have entered it to start with , the formula will not change.
Now , you need to decide whether after entering this formula in any particular cell , you will be copying it across to any other column , and if so would you want it to change or remain the same.
If you want it to change as follows :
=COUNTIF(link!D$2:D$101,1)
=COUNTIF(link!E$2:E$101,1)
then it is OK the way it has been shown above in blue , otherwise you will need to insert the $ sign before the column component also.
However , apart from all this , if you want the last parameter to change as you copy it downwards , instead of using 1 , 2 , 3 ,... use the ROW($A1) construct , as in :
=COUNTIF(link!C$2:C$101,ROW($A1))
When you copy this downwards , the $A1 will become $A2 , $A3 , $A4 ,... and the ROW function will convert it to 2 , 3 , 4 ,...
