Adding up values and grand totals through vba
helloakshay
I am generating certain numbers for a table. I am trying to write a vba code for numbers to be added row wise and column wise.
For example i want the sum of values from c2 to n2 in o2
and then move to o3 Where it should add values from c3 to n3.
I know there is a very simple way of adding values on the sheet, but i am just trying to learn how we can do it in vba.
Private Sub Command Button1_Click()
Dim ab1 As Range
Dim AB2 As Range
'Random numbers
For Each ab1 In Range("c2:n27")
ab1.Offset(0, 0).Value = Application.WorksheetFunction.RandBetween(325, 956)
Next ab1
'Adding Values
For Each AB2 In Range("o2:o27")
AB2.Offset(0, 0).Value = Application.WorksheetFunction.Sum(Range("C2: N2"))
 'From this point how will i move to the next row c3:n3 to get value on O3 and so on
Next AB2
Welcome to the forum!
First, here's one way to do it, using the worksheetfunction.sum method you've already got going.
Sub ExampleCode()
Dim ab1 As Range
Dim AB2 As Range
'Random numbers
    ab1.Value = Application.WorksheetFunction.RandBetween(325, 956)
Next ab1
'Adding Values
    AB2.Value = Application.WorksheetFunction.Sum(AB2.Offset(0, -12).Resize(1, 12))
Next AB2
Now, to explain it. Rather than giving a string to the range (e.g., Range("o2:N2")), we can remember that there are other ways of defining where a range is. Since we are in a loop, we need to keep things relative to AB2. So, we tell the code to offset by -12 columns, getting us to column C. But, we only have a single cell at this point. This is where the Resize comes in. We can then specify from our new point how many rows and how many columns to grab. Grabbing 1 row by 12 columns effectively gives us the range C2:N2.
Then, we when go to next AB2 (which is cell O3), our method will give us C3:N3.
Let me know if you have any questions about either of these methods. :)
How do we do this addition for the values in vertical columns. for example i have values in columns c to g until 5 rows in each column. i want the totals in 6th row of each column. how to write a vba code
Hi Akshay ,
Try this :
Sub ExampleCode()
    Dim ab1 As Range, ab2 As Range
    Dim rw As Range, col As Range
    Dim nc As Integer
    Dim nr As Long
    Set ab2 = Range("c2:N27")
    nc = ab2.Columns.Count
    nr = ab2.Rows.Count
'   Random numbers
     For Each ab1 In ab2
    Next ab1
'   Adding Values
     For Each rw In ab2.Rows
        rw.Cells(1, 1).Offset(, nc).Value = Application.WorksheetFunction.Sum(rw.Value)
    Next rw
    For Each col In ab2.Columns
        col.Cells(1, 1).Offset(nr).Value = Application.WorksheetFunction.Sum(col.Value)
    Next col
