Wrong with Offset formula
There is nothing wrong with the formula except the way it has been used.
If you want the SUM of all the values in the column C , then the correct formula to use would be :
=SUM(OFFSET($B$9,0,1,COUNTA($B9:$B66),1))
Dear Narayank,
I want to use this for name range, and after that apply in Data Validation for making the Dashboard to select the period.
Thanks for any kind of help.
