Work Project: Multiple Regression Model
Shane Staats
I'm guessing this is a good sized Excel job so looking for an experienced person to work on this...
Looking for someone with experience in "multiple regression model” in Excel.
I want to recreate the Excel that is spoken about in this PDF.
I have all the raw data used to create the Excel, I’m just not familiar with the techniques they used to work with it. Ending result will be the graph with blue and red lines.
Curious to what you think…
  • Research Report 2.pdf
Hi Shane ,
I do not have any experience in multiple regression ; however , I doubt that you need too much of experience to do what you want done.
Regression is available in Excel through built-in algorithms ; it is not that a user has to do anything except specify the data ranges for input and output , and a few other factors ; what matters is that the user has domain knowledge so that he / she can decide whether the results of the analysis are valid or not.
There is a lot of material on the Internet , which you can go through :
1. https://faculty.fuqua.duke.edu/~pecklund/ExcelReview/Use Excel 2007 Regression.pdf
2. http://www.excel-easy.com/examples/regression.html
3. http://cameron.econ.ucdavis.edu/excel/ex61multipleregression.html
