westcoastaccounting
hello all - great web site! i've been google searching an issue i am having w/ Excel, which usually works. but not this time!
ok so my problem is this:
under a certain column on my spreadsheet, when i enter let's say "103.16" and hit return, the number shows 103. the ".16" is NOT cut off value-wise (just cosmetically), because it becomes visible if i double-click its cell, and is also visible in the horizontal "fX" field on the top of the sheet when i mouse over. and this is isn't even a problem on the whole column, because cells let's say 1-100 show decimals. but starting at let's say 101, everything below in this certain column cuts off the decimals. it isn't rounding the number. it's just not showing the aforementioned ".16".
(not a column width problem, as columns are plenty wide and i've experimented with this.)
if anyone has any insight into this, would be much appreciated. thank you so much for reading!
