I have two worksheets both of which have last name and first name of residents. one worksheet has the delinquency/prepaid amount and I need to do a lookup by name and bring the delinquency/prepaid amount into the the second worksheet. The lastname is in the first column in both worksheets. Both sheets are in alpha order by last name. the formula i have entered on the first worksheet is:
=VLOOKUP($A2,B_EOM!$A$10:$A$227,5,FALSE) A2 is the last name on the first sheet, A10:A227 in the second worksheet (B_EOM) is also the last name. The delinquency/prepaid amount is in the 5th position from the last name in the B_EOM worksheet. I have very similar formula on other worksheets with success so I am confused as to why it isn't working. I am mostly getting #REF on most and and few #NA. on the #REF the names are the same on both sheets. Help please. in addition if there is a way to look not only at last name but last name and first name that would be great. Do I need to combine them with a comma or can I do it with them in their own columns?
