N Nandakumar Member Mar 5, 2017 #1 Hi, I need a formula help on the attache worksheet. I have two values which needs to be compared if one row contains that value,else it should do normal vlookup. Hope you understand attached worksheet. Attachments Chandoo_05Mar17.xlsx 10.1 KB · Views: 15
B bosco_yip Excel Ninja Mar 5, 2017 #2 In "Formula Required" Sheet D3, formula copy across and down : =IFERROR(VLOOKUP($B3,Grouping!$B$2:$I$7,COLUMNS($A1:B1),0),VLOOKUP($C3,Grouping!$A$2:$I$7,COLUMNS($A1:C1),0)) Regards
N Nandakumar Member Mar 5, 2017 #3 Thanks.Perfect. It works! bosco_yip said: In "Formula Required" Sheet D3, formula copy across and down : =IFERROR(VLOOKUP($B3,Grouping!$B$2:$I$7,COLUMNS($A1:B1),0),VLOOKUP($C3,Grouping!$A$2:$I$7,COLUMNS($A1:C1),0)) Regards Click to expand...
