VBA to compare duplicates and add in same rows
rajesh2022
Hello All
We are in the process building a logic which is as follows:
1. We are having 2 columns which contains duplicate values as well. For example
NameValue
RajeshTech Lead
RameshSupervisor
RajeshManager
RajeshStore Keeper
RobManager
RobStore Keeper
RobTech Lead
I need to create another column which needs to check for duplicate and add as below : (Expected Output)
NameValueOutput 1Output 2
RajeshTech LeadManagerStore Keeper
RameshSupervisor
RajeshManagerTech LeadStore Keeper
RajeshStore KeeperManagerTech Lead
RobManagerStore KeeperTech Lead
RobStore KeeperManagerTech Lead
RobTech LeadManagerStore Keeper
Basically i don't want to delete duplicates, but i want to show in another columns,
Can we achieve in VBA? Any guidance would be great
  • Compare_list - Copy (1).xlsx
Hello,​
it shoud be achieved with differents ways, like using Excel basics or some activeX like a Dictionary.​
But as it depends on the real worksheet …​
According to your attachment why "Okta-NewgenOneFlow-PRDUsers" is not in the expected result ?!​
According to your attachment a VBA demonstration for starters :​
Sub Demo1()
        Dim Dic As Object, V, R&, W
        Set Dic = CreateObject("Scripting.Dictionary")
    With Sheet1.UsedRange.Columns
            V = .Item("A:B").Value2
            If .Count > 2 Then .Item(3).Resize(, .Count - 2).Clear
        For R = 2 To .Rows.Count
            If Dic.Exists(V(R, 1)) Then
                W = Dic(V(R, 1))
                ReDim Preserve W(UBound(W) + 1)
                W(UBound(W)) = V(R, 2)
                Dic(V(R, 1)) = W
                Dic(V(R, 1)) = Array(V(R, 2))
            W = Filter(Dic(V(R, 1)), V(R, 2), False)
            If UBound(W) > -1 Then .Cells(R, 3).Resize(, UBound(W) + 1).Value2 = W
        Dic.RemoveAll
        Set Dic = Nothing
        If .Count > 2 Then
            With .Item(3).Resize(, .Count - 2)
                 .Borders.Weight = 2
                 .Rows(1).Interior.ColorIndex = 36
                 .Rows(1).HorizontalAlignment = xlCenter
                 .Rows(1).Value2 = Evaluate("COLUMN(A1:" & Cells(.Count).Address & ")")
           .AutoFit
           .VerticalAlignment = xlCenter
