VBA to clear contents based on criteria being met
Caesar
I am new to VBA and want to write a macro for the following:
If cell B2 is blank then clear contents from cells F2:F3. If cell B2 has a value then do nothing. The same has to be done for B6 and F6:F7 and for other specific cells in the worksheet.
Any help is appreciated.
Caesar
One sample of that ...
Hi vletm, thank you for your response.
Unfortunately that does not seem to work the way I intended.
When the value in B2 changes to a blank cell, the cells B6:B7 must automatically get cleared (without using a control button).
Caesar
Did You mention before:
the cells B6:B7 must automatically get cleared (without using a control button).?
I could not read that from You mind!
It worked as a sample, which needed to 'trigger' someway.
Caesar
Hi vletm
Apologies the first post was not clear what had to be done.
Thank you for your assistance.
