VBA - small code required
vasim
How can I make this code small....
Private Sub Calendar1_Click()
'Calendar value in textbox
UserForm1.TextBox13.Value = Format(Calendar1.Value, "dd/mmm/yyyy")
Calendar1.Visible = False
Private Sub Calendar2_Click()
UserForm1.TextBox14.Value = Format(Calendar2.Value, "dd/mmm/yyyy")
Calendar2.Visible = False
Private Sub Calendar3_Click()
UserForm1.TextBox15.Value = Format(Calendar3.Value, "dd/mmm/yyyy")
Calendar3.Visible = False
Private Sub Calendar4_Click()
UserForm1.TextBox16.Value = Format(Calendar4.Value, "dd/mmm/yyyy")
Calendar4.Visible = False
Private Sub Calendar5_Click()
UserForm1.TextBox17.Value = Format(Calendar5.Value, "dd/mmm/yyyy")
Calendar5.Visible = False
Private Sub Calendar6_Click()
UserForm1.TextBox28.Value = Format(Calendar6.Value, "dd/mmm/yyyy")
Calendar6.Visible = False
Private Sub Calendar7_Click()
UserForm1.TextBox29.Value = Format(Calendar7.Value, "dd/mmm/yyyy")
Calendar7.Visible = False
Private Sub Calendar8_Click()
UserForm1.TextBox31.Value = Format(Calendar8.Value, "dd/mmm/yyyy")
Calendar8.Visible = False
Private Sub Calendar9_Click()
UserForm1.TextBox30.Value = Format(Calendar9.Value, "dd/mmm/yyyy")
Calendar9.Visible = False
You can construct this using IF clause...but may I request you to please upload your workbook so that we can test the code with the data before posting it.
Kaushik
Since it's a different text box for each control, and there's no self-reference name/shortcut for controls, I'm not sure we can shorten it up much. =(
One thought, do you really need multiple calendar controls? Perhaps you could just use 1, and then show/hide it as needed to get values for your text boxes.
Hi, Indian!
Deleting 9 calendar and 9 text box controls is suitable for you?
It'd be the better approach to the most minimalist option...
Regards!
