VBA Macro eliminate double copy
Msc
Hi everyone,
I am appending monthly data to my master excel file from txt files, i want to write elimination code, that if one month data let say Feb.16 data has been copied and user run the same macro for feb.16 again, it should not copy the same data again.
Please help.
Mod Edit: Thread moved to VBA
You can just record "Remove Duplicate" operation from Data Tab and adjust to suite your need.
If further help is needed, you'd get much better help if you have sample file with enough data and your code.
