VBA help
sa.1985
Dear All,
I have created a column as id number, Sheetname "Dataentry"'s rows data will transfer in same id number's sheets ( other sheets name i given as ID )
Cell A1 = 1 ( 1 is id number )
Cell A2 = 2 ( 2 is id number )
Cell A3 = 3 ( 3 is id number )
Cell A4 = 1 ( Repeated id number )
Cell A5 = 2 ( Repeated if number )
as above i mentioned in column A:A is id number , Here i want.........
if cell A1 = 1 then this row's data transfer to sheetname 1
if cell A2 = 2 then this row's data transfer to sheetname 2
if cell A3 = 3 then this row's data transfer to sheetname 3
if cell A4 = 1 then this row's data transfer to sheetname 1 ( this is repeated )
Hi
Run the sub Tansfer (I guess that your destination sheets name is 1, 2,...etc)
[pre]
Sub Transfer()
Dim LastRow As Long, i As Long
Dim ShtName As String
With Worksheets("Dataentry")
LastRow = .Cells(.Rows.Count, 1).End(xlUp).Row
For i = 1 To LastRow
ShtName = CStr(.Range("A" & i))
If SheetExists(ShtName) Then .Rows(i).Copy Worksheets(ShtName).Cells(Worksheets(ShtName).Rows.Count, 1).End(xlUp)(2)
Private Function SheetExists(ByVal Str As String) As Boolean
Dim Sh As Worksheet
If Str <> "" Then
For Each Sh In ThisWorkbook.Worksheets
If Sh.Name = Str Then
SheetExists = True
Exit For
Next Sh
End Function
[/pre]
Dear Sir
Thank u so much, but here a problem that ...
when i enter second entry by same id ( for example id no : 1) in data entry sheet then sheetname 1's entry increasing , it should not to be .
Here the code modified
[pre]
Sub Transfer()
Dim ShtName As String, Result As String
With ThisWorkbook.Worksheets("Dataentry")
For i = LastRow To 1 Step -1
If InStr(Result, "," & ShtName) = 0 Then
.Rows(i).Copy Worksheets(ShtName).Range("A1")
Result = Result & "," & ShtName
Dim Sh As Worksheet
If Str <> "" Then
SheetExists = True
Exit For
Next Sh
End Function
[/pre]
