I've just completed a rather large product/pricing model and realised that unless I have something that allows the actual data (formula) to be pasted as values, I will have do a lot of manual copy/pasting everything I open a file.
This is way beyond my VBA skills (even been generous to myself by saying I have VBA skills!)
This is what I need to do (I've mocked up the file too).
Starting column M, and setting a counter at 10
Select M12:M63
Copy, Paste Values Only in N12:N63
Then count from column N, across 7 columns to column T; so count would now be 17
Select T12:T63
Copy, Paste Values Only in U12:U63
Repeat this, i.e. count across 7 columns (would take you to column AA), copy column 12:63, paste values into next column (AB) 12:63 (adding 7 to the counter each time)
Do this until count =MAX(ProdList!L9:L28) - this is because I have various files, all with different number of products.
https://dl.dropboxusercontent.com/u/9071274/VBA to paste values across range with counter.xlsx
Any help here would hugely appreciated.
thanks
Select M12:M63
Select T12:T63
thanks
