Sub RDB_Merge_Data_Browse()
Dim myFiles As Variant
Dim myCountOfFiles As Long
Dim oApp As Object
Dim oFolder As Variant
Set oApp = CreateObject("Shell.Application")
'Browse to the folder
Set oFolder = oApp.BrowseForFolder(0, "Select folder", 512)
If Not oFolder Is Nothing Then
myCountOfFiles = Get_File_Names( _
MyPath:=oFolder.Self.path, _
Subfolders:=False, _
ExtStr:="*.xl*", _
myReturnedFiles:=myFiles)
If myCountOfFiles = 0 Then
MsgBox "No files that match the ExtStr in this folder"
Exit Sub
Get_Data _
FileNameInA:=False, _
PasteLink:=True, _
SourceShName:="Break metrics", _
SourceShIndex:=2, _
SourceRng:="D170:F170", _
StartCell:="", _
Sub Get_Data(FileNameInA As Boolean, PasteLink As Boolean, SourceShName As String, _
SourceShIndex As Integer, SourceRng As String, StartCell As String, myReturnedFiles As Variant)
Dim SourceRcount As Long
Dim sourceRange As Range, destrange As Range
Dim mybook As Workbook, BaseWks As Worksheet
Dim rnum As Long, CalcMode As Long
Dim SourceSh As Variant
Dim sh As Worksheet
Dim i As Long
'Change ScreenUpdating, Calculation and EnableEvents
With Application
CalcMode = .Calculation
.Calculation = xlCalculationManual
.ScreenUpdating = False
.EnableEvents = False
.DisplayAlerts = False
'Add a new workbook with one sheet named "Combine Sheet"
' come back later and see if I can change this to my template workbook with Set BaseWks = Activeworkbook.Activeworksheets(Sheet1)
Set BaseWks = Workbooks.Add(xlWBATWorksheet).Worksheets(1)
BaseWks.Name = "Combine Sheet"
'Set start row for the Data
rnum = 1
'Check if we use a named sheet or the index
If SourceShName = "" Then
SourceSh = SourceShIndex
SourceSh = SourceShName
'Loop through all files in the array(myFiles)
For i = LBound(myReturnedFiles) To UBound(myReturnedFiles)
Set mybook = Nothing
Set mybook = Workbooks.Open(myReturnedFiles(i))
On Error GoTo 0
If Not mybook Is Nothing Then
If LCase(SourceShName) <> "all" Then
'Set SourceRange and check if it is a valid range
If StartCell <> "" Then
With mybook.Sheets(SourceSh)
Set sourceRange = .Range(StartCell & ":" & RDB_Last(3, .Cells))
'Test if the row of the last cell >= then the row of the StartCell
If RDB_Last(1, .Cells) < .Range(StartCell).Row Then
Set sourceRange = Nothing
Set sourceRange = Application.Intersect(.UsedRange, .Range(SourceRng))
If Err.Number > 0 Then
Err.Clear
'if SourceRange use all columns then skip this file
If sourceRange.Columns.count >= BaseWks.Columns.count Then
On Error GoTo 0
If Not sourceRange Is Nothing Then
'Check if there enough rows to paste the data
SourceRcount = sourceRange.Rows.count
If rnum + SourceRcount >= BaseWks.Rows.count Then
MsgBox "Sorry there are not enough rows in the sheet to paste"
mybook.Close SaveChanges:=False
BaseWks.Parent.Close SaveChanges:=False
GoTo ExitTheSub
'Set the destination cell
If FileNameInA = True Then
Set destrange = BaseWks.Range("B" & rnum)
With sourceRange
BaseWks.Cells(rnum, "A"). _
Resize(.Rows.count).Value = myReturnedFiles(i)
Set destrange = BaseWks.Range("A" & rnum)
'Copy/paste the data
If PasteLink = True Then
With sourceRange
Set destrange = destrange. _
Resize(.Rows.count, .Columns.count)
destrange.Value = sourceRange.Value
sourceRange.Copy destrange
rnum = rnum + SourceRcount
'Close the workbook without saving
'Loop through all sheets in mybook
For Each sh In mybook.Worksheets
With sh
With sh
Err.Clear
'if SourceRange use almost all columns then skip this file
If sourceRange.Columns.count > BaseWks.Columns.count - 2 Then
On Error GoTo 0
GoTo ExitTheSub
Set destrange = BaseWks.Range("C" & rnum)
With sourceRange
BaseWks.Cells(rnum, "B"). _
Resize(.Rows.count).Value = sh.Name
With sourceRange
destrange.Link = sourceRange.Value
Next sh
'Open the next workbook
'Set the column width in the new workbook
BaseWks.Columns.AutoFit
ExitTheSub:
'Restore ScreenUpdating, Calculation and EnableEvents
With Application
.ScreenUpdating = True
.EnableEvents = True
.Calculation = CalcMode
