VBA for index match with 2 criterias
I need help on my monitoring form.
I need to know how to make a vba code for my index-match formula.
The formula is working fine but i just noticed that it makes the file size very big as we continue to input data.
I have a control sheet wherein all the reserv and matcode and quantity are stored.
On the other sheet "data", i need the get the value of quantity based from the given reserv and matcode.
Please help.
Thank you!
__________________________________________________________________
Mod edit : thread moved to appropriate forum !
  • Chandoo-Sample.xlsx
If you can upload your full workbook instead of a sample having just a few rows of data , we could have tested different approaches using a formula-based solution.
Can you try this approach with your actual workbook ?
I have assumed that only one row will match , since you are using the MATCH function yourself ; if there will be more than one row which matches , my approach will not work.
Hi Narayan,
Thank you for the reply.
I just need to know how to transform my index-match formula into a vba code.
The point I was trying to make was that even if you decide to go in for VBA code , the code should implement the most efficient formula , assuming that you wish to implement the formula in your code. After all , code can possibly achieve what you want , without using any formula.
What you want is the most efficient approach , whether it is using pure formulae , or implementing a formulae-based solution using code , or using pure code without resorting to formulae.
This will only be possible if you upload your actual workbook having as much data as possible.
Clarify what you want , and if you do not wish to upload your full workbook.
Hi Narayan,
Sorry I am trying to upload my monitoring, but seems like it was not supported. Is there other way to upload here?
Thank you!
Hi Narayan, sorry this is out of thread, but this is my monitoring form for last week. Thank you!
See if this is fast enough.
There is no code in the file for the solution , though it is a macro enabled file , because I have included some code for doing a manual recalculate.
  • Chandoo-Sample (1).xlsm
