VBA Code to split a range on cells equally
sn152
Hi All,
I am trying to do a macro which will split a data range equally.
For example, in the attached workbook I have data in sheet1 in cells from A1 to E15.
I want that to be split equally among 6 teams (team A, B, C, D, E, F) and paste the split data in a separate workbook. I have also attached that workbook.
Please help me with this.
Thanks in advance...
This should do it for you. Just make sure to list all your teams where commented.
Sub DivideTeams()
Dim TeamList()
Dim TeamCount As Long
Dim recCount As Long
Dim evenDiv As Long
Dim extraRecs As Long
Dim lastRow As Long
Dim teamChoice As Long
Dim i As Long
Dim j As Long
'Who are the teams?
TeamList = Array("Team A", "Team B", "Team C", "Team D", "Team E", "Team F")
teamChoice = 0
TeamCount = UBound(TeamList) + 1
i = 1
'Make new workbook
ActiveSheet.Copy
With ActiveSheet
    'Math calculations
    lastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
    recCount = lastRow - 1
    extraRecs = recCount Mod TeamCount
    evenDiv = (recCount - extraRecs) / TeamCount
    Do While i < lastRow
        'Every team gets at least the same amount
        For j = 1 To evenDiv
            i = i + 1
            .Cells(i, "F").Value = TeamList(teamChoice)
        Next j
        'Check if uneven amount, and if so, add a line
        If j = evenDiv + 1 And extraRecs > 0 Then
            i = i + 1
            extraRecs = extraRecs - 1
        'Next team queued up
        teamChoice = teamChoice + 1
    Loop
Hi Luke,
One more request. Can we have the team names to show in the last column instead of mentioning it as "F".
Sure thing. Added a few lines to deal with new variable, lastCol
Sub DivideTeams()
Dim TeamList()
Dim evenDiv As Long
Dim lastRow As Long
Dim lastCol As Long
Dim i As Long
Dim j As Long
'Who are the teams?
teamChoice = 0
i = 1
'Make new workbook
ActiveSheet.Copy
With ActiveSheet
    'Math calculations
   'Always find the first blank column
   lastCol = .Cells(1, Columns.Count).End(xlToLeft).Column + 1
            i = i + 1
            .Cells(i, lastCol).Value = TeamList(teamChoice)
        Next j
            i = i + 1
    Loop
Hi Luke,
Also I need to add a Heading to the last column as "Assigned to". Can you pls help me..
Add a line at the end, just before the "End With" saying:
.Cells(1, lastCol).Value = "Assigned to"
@sn152
Just a personal query on your post, you mentioned in your 1st post that you want to divide equally, but what I can see Team A & B has 3 records each and Team C, D & E has two records each. So my question is it really equal and on what basis?
@Somendra Misra
Equal in the sense, if the total count is a number which cannot be divided equally then there will be a increase in the number assigned to one or two teams...
Ok @sn152 .... But there will not be why A & B only get 3 if we made an array of teams like {E;C;D;B;A} then E and C will get 3.
Will this hamper the result?
@Luke M
Hi Luke,
The above code by you splits the data range equally among the teams.
But for example when we have 7 rows filled in the sheet, we cannot split it equally among six teams. 1 team may get more numbers. In this case for example if there are 7 rows are filled, can we have 6 rows split among the 6 teams and remaining 1 row should not be assigned. Can we do it this way?
Thanks in advance!
Yep. I added in a MsgBox to prompt user if extra rows found.
Sub DivideTeams()
Dim TeamList()
Dim evenDiv As Long
Dim lastRow As Long
Dim lastCol As Long
Dim i As Long
Dim j As Long
Dim skipExtra As Boolean
skipExtra = False
'Who are the teams?
teamChoice = 0
i = 1
'Make new workbook
ActiveSheet.Copy
With ActiveSheet
    'Math calculations
    If extraRecs > 0 Then
        If vbYes <> MsgBox("Click yes to create uneven teams" & vbNewLine & _
            "or click no to ignore extra lines", vbYesNo, "Extra lines found") Then
            lastRow = lastRow - extraRecs
            skipExtra = True
            i = i + 1
        Next j
      If j = evenDiv + 1 And extraRecs > 0 And skipExtra = False Then
            i = i + 1
    Loop
Hello Luke,
i am trying to modify your code, as i want to input the list of team members from another worksheet, instead of defining it in the code. after modification i am getting an error by saying that "Runtime error 9: Script out of Range"
could you please help me here. Below is modified Code.
Sub DivideTeams()
Dim TeamList As Variant
'Dim TeamList()
Dim SourceTeam As Range
Dim evenDiv As Long
Dim lastRow As Long
Dim lastCol As Long
Dim i As Long
Dim j As Long
Dim ws1 As Worksheet
Dim ws2 As Worksheet
Dim ws3 As Worksheet
Set ws1 = Sheets("Team")
Set ws3 = Sheets("Consolidation Tracker")
With ws1
Dim lastRow1 As Long
Dim lastRow2 As Long
lastRow1 = Sheets("Team").Cells(.Rows.Count, "A").End(xlUp).Row
lastRow2 = Sheets("In Team").Range("A:A").End(xlUp).Row
For i = 5 To lastRow1
If ws1.Cells(i, 2) = "In" Then ws1.Cells(i, 1).Copy Destination:=Sheets("In Team").Range("A100").End(xlUp)(2, 1)
'Who are the teams?
'TeamList = Array("Team A", "Team B", "Team C", "Team D", "Team E", "Team F")
Set SourceTeam = Sheets("In Team").Range("A1:A5").CurrentRegion
TeamList = SourceTeam.Value
teamChoice = 0
i = 1
'Make new workbook
ws3.Copy
'ActiveSheet.Copy
With ActiveSheet
'Math calculations
i = i + 1
.Cells(i, lastCol).Value = TeamList(teamChoice) 'in this line i am geeting error as Runtime error, script our of range
Next j
i = i + 1
Loop
Hi Anudeep, and welcome to the forum. :awesome:
Since the values of TeamList are coming from a range now, it's actually a 2D array rather than a 1D. As such, need to provide 2 arguments. See if this works better for you.
Sub DivideTeams()
    Dim evenDiv As Long
    Dim lastRow As Long
    Dim lastCol As Long
    Dim i As Long
    Dim j As Long
    With ws1
        lastRow1 = .Cells(.Rows.Count, "A").End(xlUp).Row
            If .Cells(i, 2) = "In" Then .Cells(i, 1).Copy Destination:=Sheets("In Team").Range("A100").End(xlUp)(2, 1)
    'Who are the teams?
    teamChoice = 1
    i = 1
    'Make new workbook
    ws3.Copy
    'ActiveSheet.Copy
    With ActiveSheet
        'Math calculations
                i = i + 1
                'since TeamList is from a range, it's now a 2D array, so needs 2 arguments
                .Cells(i, lastCol).Value = TeamList(teamChoice, 1)
            Next j
                i = i + 1
        Loop
Hi Luke,
Hope this is still active and that I'm able to highjack this tread. I have been using your code and it works well, thank you. The only thing that I have been struggling with is getting your code to look at values in said col and assign equally, but first look at the values and group any unique values to one team. I have a list of orders (Sometimes duplicated) and currently its then being split between different teams.
Would appreciate any help.
Hi Moondog. Could you give a sample of what you mean (what you have now + what you want it to look like)?
Hello people,
Can anyone help me for VBA code. Below is the matter.
I have a excel main sheet named (Main) which contains bulk data.
other worksheets named A, B, C, D
I want to apply filter first in main sheet then distribute those rows equally in other sheets.
Again, i want to apply filter in header and resulting rows should divide and add in other sheets equally.
and so on...... in same way.
Thanks in Advance.....
gurtej
As You've read from Forum Rules ( New Users - Please Start Here >> )
Start a new post every time you ask a question, even if the theme is similar. The original author may continue asking questions whilst the post is in progress and of course if you are answering questions you may need to ask questions of the initial poster.
