I have below macro code to run sumifs formula; however it's taking too long to execute the code and it eventually crashes. Anyone may know whats causing the issue. Thanks
'FE FORMBRAND LW
Sub SUMIFSLWFORMBRAND()
Const TOTALSROW = 73
Dim i, x, y, z, t, f, u, q, w, s, n, a, b, c, k, l As Long
With Sheets("FE")
.Cells(TOTALSROW, 7) = WorksheetFunction.SUMIF(Sheets("Source").Range("CI:CI"), .Cells(TOTALSROW, 5), Sheets("Source").Range("av:av"))
.Cells(TOTALSROW, 8) = WorksheetFunction.SUMIF(Sheets("Source").Range("CI:CI"), .Cells(TOTALSROW, 5), Sheets("Source").Range("aw:aw"))
For x = 2 To 12
.Cells(TOTALSROW + x, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + x, 4), Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + x, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + x, 6))
.Cells(TOTALSROW + x, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + x, 4), Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + x, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + x, 6))
For i = 1 To 1
.Cells(TOTALSROW + i, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + i, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + i, 4))
.Cells(TOTALSROW + i, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + i, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + i, 4))
For y = 13 To 13
.Cells(TOTALSROW + y, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + y, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + y, 4))
.Cells(TOTALSROW + y, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + y, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + y, 4))
For z = 14 To 23
.Cells(TOTALSROW + z, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + z, 4), Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + z, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + z, 6))
.Cells(TOTALSROW + z, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + z, 4), Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + z, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + z, 6))
For t = 24 To 24
.Cells(TOTALSROW + t, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + t, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + t, 4))
.Cells(TOTALSROW + t, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + t, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + t, 4))
For f = 25 To 28
.Cells(TOTALSROW + f, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + f, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + f, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + f, 6))
.Cells(TOTALSROW + f, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + f, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + f, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + f, 6))
For u = 29 To 29
.Cells(TOTALSROW + u, 7) = WorksheetFunction.SUMIF(Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + u, 5), Sheets("Source").Range("av:av"))
.Cells(TOTALSROW + u, 8) = WorksheetFunction.SUMIF(Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + u, 5), Sheets("Source").Range("aw:aw"))
For q = 30 To 30
.Cells(TOTALSROW + q, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + q, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + q, 4))
.Cells(TOTALSROW + q, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + q, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + q, 4))
For w = 31 To 37
.Cells(TOTALSROW + w, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + w, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + w, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + w, 6))
.Cells(TOTALSROW + w, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + w, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + w, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + w, 6))
For s = 38 To 38
.Cells(TOTALSROW + s, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + q, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + s, 4))
.Cells(TOTALSROW + s, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + q, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + s, 4))
For n = 39 To 42
.Cells(TOTALSROW + n, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + n, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + n, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + n, 6))
.Cells(TOTALSROW + n, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + n, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + n, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + n, 6))
For a = 43 To 43
.Cells(TOTALSROW + a, 7) = WorksheetFunction.SUMIF(Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + a, 5), Sheets("Source").Range("av:av"))
.Cells(TOTALSROW + a, 8) = WorksheetFunction.SUMIF(Sheets("Source").Range("CB:CB"), .Cells(TOTALSROW + a, 5), Sheets("Source").Range("aw:aw"))
For b = 44 To 44
.Cells(TOTALSROW + b, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + b, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + b, 4))
.Cells(TOTALSROW + b, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + b, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + b, 4))
For c = 45 To 53
.Cells(TOTALSROW + c, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + c, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + c, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + c, 6))
.Cells(TOTALSROW + c, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + c, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + c, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + c, 6))
For k = 54 To 54
.Cells(TOTALSROW + k, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + k, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + k, 4))
.Cells(TOTALSROW + k, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + k, 5), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + k, 4))
For l = 55 To 58
.Cells(TOTALSROW + l, 7) = WorksheetFunction.SUMIFS(Sheets("Source").Range("av:av"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + l, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + l, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + l, 6))
.Cells(TOTALSROW + l, 8) = WorksheetFunction.SUMIFS(Sheets("Source").Range("aw:aw"), Sheets("Source").Range("CC:CC"), .Cells(TOTALSROW + l, 4), Sheets("Source").Range("Cb:Cb"), .Cells(TOTALSROW + l, 5), Sheets("Source").Range("CG:CG"), .Cells(TOTALSROW + l, 6))
Next l
Next k
Next c
Next b
Next a
Next n
Next s
Next w
Next q
Next u
Next f
Next t
Next z
Next y
Next x
