vba code running slowly.
I have written a code to open a workbook on a network and calculate a QTY through sumifs formula with 2 criteria. I have 6000 parts and 10 products i am comparing the network file against. the network file is about 70,000 lines. i have tried looping the formula several ways. one line item and product at a time. one line item and all 10 products. all line items and 1 product, all line and all products. either way it is taking 25 minutes to calculate. then i have to format the cells against its required qty to what has been issued to the product. i have posted my code below. I had to delete path and file specific names,
Sub Populate()
Dim AC As String
Dim ACcount As Integer
Dim Parts As Integer
Dim i As Integer
Dim Qty As Long
Dim DataP As Double
Dim Cell As String
Dim P As Integer
Workbooks.Open Filename:= _
"network File"
Windows("network file").Activate
Range("A1").Select
DataP = Range(Selection, Selection.End(xlDown)).Count
Workbooks("current file").Activate
Sheets("sheet i am using in current file").Select
Range("H1").Select 'count products
ACcount = Range(Selection, Selection.End(xlToRight)).Count
Range("A2").Select
Parts = Range(Selection, Selection.End(xlDown)).Count ' counts line items
Range("H1").Select
' Range("A1").Select
'ActiveCell.Offset(0, i + 7).Select 'sets starting point for calculation against network file
' AC = ActiveCell.Value
For P = 1 To Parts
ActiveCell.Range(Cells(P, 1), Cells(P, ACcount)).Formula = _
"=SUMIFS('[network file.xlsm]Data'!R1C10:R" & DataP & "C10,'[network file.xlsm]Data'!R1C8:R" & DataP & "C8,RC1,'[network file.xlsm]Data'!R1C21:R" & DataP & "C21,R1C)"
' ActiveCell.Range(Cells(P, 1), Cells(1, ACcount)).Value = ActiveCell.Range(Cells(P, 1), Cells(1, ACcount)).Value
Qty = ActiveCell.Offset(P - 1, -3).Value 'this section formats cells. "i have tried removing this and just get the numbers to make it faster, but to no avail."
For i = 1 To ACcount
If ActiveCell.Offset(P - 1, i - 1).Value < Qty Then
'Red
ActiveCell.Offset(P - 1, i - 1).Interior.Color = 192
If ActiveCell.Offset(P - 1, i - 1).Value >= Qty Then
'Green
ActiveCell.Offset(P - 1, i - 1).Interior.Color = 5287936
'removing formula and setting values
ActiveCell.Range(Cells(1, 1), Cells(Parts, ACcount)).Value = ActiveCell.Range(Cells(1, 1), Cells(Parts, ACcount)).Value
Workbooks("network file".xlsm").Close savechanges:=False
just some quick observations:
1) Near the end of the code, where you color the cells, I would just use the conditional formatting thats built into excel. I always try to use as much that is native to excel as i can
2) I havent really dove into this code, but seems to be a of "select". Theres no need to select it in vba, as you can still reference it.
maybe if I have some time later I will look at more, but reading it as its formatted on the forum isn't the greatest (ie no idents, coloring, etc)
sorry about the format, it pasted that way and i didn't adjust it. i tried using the conditional format and becuase of the size of the range, it really bogs the spreadsheet. can you assist on the reference concepts. that would be very helpful. I think that that concept is my crux right now.
In case anyone wants to debug the code , here it is , in indented form :
[pre]
Sub Populate()
Dim AC As String
Dim Cell As String
Dim i As Integer
Dim P As Integer
Dim Qty As Long
Dim DataP As Double
Workbooks.Open Filename:="network File"
Range("A1").Select
Range("A2").Select
Range("H1").Select
For P = 1 To Parts
'Red
'Green
Workbooks("network file.xlsm").Close savechanges:=False
[/pre]
