Dear Sir,
As enclosed in attachment,I did not get result in Column I,perhaps there is some sort of error in vba code while running ,kindly have a look into it and resolve the issue,it would be a great help to me.The vba code is as follows with file enclosed in attachment.
Thanks in advance,
With Best Rgds,
Sub LIFO()
Dim a As Variant, Cost As Double, sumIn As Double, sumOut As Double, _
i As Long, ii As Long
With Application
.ScreenUpdating = False
.Calculation = xlCalculationManual
With Sheets("LIFO")
.Range("i7", .Cells(Rows.Count, "i").End(xlUp)).ClearContents
a = .Range("e7", .Cells(Rows.Count, "g").End(xlUp)).Resize(, 5).Value
For i = LBound(a, 1) To UBound(a, 1)
If Not IsEmpty(a(i, 3)) Then
sumOut = a(i, 3)
For ii = i - 1 To 1 Step -1
If Not IsEmpty(a(ii, 2)) Then
sumIn = sumIn + a(ii, 2)
If sumIn > sumOut Then
Exit For
Cost = Cost + a(ii, 1) * a(ii, 2)
a(ii, 2) = Empty
If sumIn - sumOut > 0 Then
Cost = (Cost + (a(ii, 1) * (a(ii, 2) - (sumIn - sumOut)))) / sumOut
a(ii, 2) = sumIn - sumOut
Cost = Cost / sumOut
a(i, 5) = Cost
sumIn = 0: sumOut = 0: Cost = 0: n = ii
.Range("i7").Resize(UBound(a, 1)) = Application.Index(a, , 5)
Erase a
With Application
.ScreenUpdating = True
.Calculation = xlCalculationAutomatic
Erase a
Sub AVR_COST()
Dim a, i As Long, Bal As Double, Debit As Double
Dim AVcost As Double
With Application
.EnableEvents = False
With Sheets("AVR COST")
a = .Range("e7", .Cells(.Rows.Count, "g").End(xlUp)).Resize(, 3).Value
.Range("i7", .Cells(.Rows.Count, "i").End(xlUp)).ClearContents
ReDim Preserve a(1 To UBound(a, 1), 1 To 4)
If a(i, 2) > 0 Then
Bal = Bal + a(i, 2)
Debit = Debit + a(i, 1) * a(i, 2)
AVcost = Debit / Bal
ElseIf a(i, 3) > 0 Then
a(i, 4) = AVcost
Debit = Debit - a(i, 3) * AVcost
Bal = Bal - a(i, 3)
.Range("i7").Resize(UBound(a, 1)) = Application.Index(a, 0, 4)
Erase a
With Application
.EnableEvents = True
With Best Rgds,
