VBA code issue
Kmahraz
Hey Guys,
Doing a quick presentation to our sales team using the attached file to show how you can:
Send email with attachment
PDF report and save to a specific location
I found this one very interesting, and would like to make some slight modification to make it work.
When I press:
  1. "Sent Dist email" I notice that nothing happen?
  2. "Send test email "and add more distributors to the list, I receive only 4 emails?
  3. I would like for the name of the file when its saved into the folder to begin with distributor number Column A, sheet "Store list"
Or if any of you have a better example that I can use in my presentation .. please share it.
Any help will be greatly appreciated.
Please see file attached.
K
  • Chandoo email test file.xlsm
Sub SendEmailTest()
SendEmailWithPDF (True)
Sub SendEmailStores()
SendEmailWithPDF (False)
Sub SendEmailWithPDF(bTest As Boolean)
Dim wsM As Worksheet
Dim wsL As Worksheet
Dim wsR As Worksheet
Dim wsS As Worksheet
Dim rngL As Range
Dim rngSN As Range
Dim rngPath As Range
Dim c As Range
Dim lSend As Long
Dim lCount As Long
Dim OutApp As Object
Dim OutMail As Object
Dim strSavePath As String
Dim strPathTest As String
Dim strPDFName As String
Dim strSendTo As String
Dim strSubj As String
Dim strBody As String
Dim strMsg As String
Dim strConf As String
On Error GoTo errHandler
strMsg = "Could not set variables"
Set wsM = wksMenu
Set wsS = wksSet
Set wsL = wksList
Set wsR = wksRpt
Set rngL = wsL.Range("StoreNums")
Set rngSN = wsR.Range("rngSN")
Set rngPath = wsS.Range("rngPath")
lCount = rngSN.Cells.Count
If bTest = True Then
   strConf = "TEST Emails: "
   strConf = "STORE Emails: "
strConf = strConf & wsS.Range("rngCountMail").Value
strConf = strConf & vbCrLf & vbCrLf
strConf = strConf & "Please confirm: Do you want to send the emails?"
lSend = MsgBox(strConf, vbQuestion + vbYesNo, "Send Emails")
If lSend = vbYes Then
   strSubj = wsS.Range("rngSubj").Value
   strBody = wsS.Range("rngBody").Value
   strSendTo = wsS.Range("rngSendTo").Value
   strSavePath = rngPath.Value
   strMsg = "Could not test Outlook"
   Set OutApp = GetObject(, "Outlook.Application")
   If OutApp Is Nothing Then
       MsgBox "Outlook is not open, open Outlook and try again"
       GoTo exitHandler
   strMsg = "Could not set path for PDF save folder"
   If Right(strSavePath, 1) <> "\" Then
       strSavePath = strSavePath & "\"
   If DoesPathExist(strSavePath) Then
     'continue code below, using strSavePath
     MsgBox "The Save folder, " & strSavePath _
       & vbCrLf & "does not exist." _
       & vbCrLf & "Files could not be created." _
       & vbCrLf & "Please select a valid folder."
       wsS.Activate
       rngPath.Activate
     GoTo exitHandler
   strMsg = "Could not start mail process"
   For Each c In rngL
      rngSN = c.Value
      strMsg = "Could not create PDF for " & c.Value
      strPDFName = "SalesReport_" & c.Value & ".pdf"
      'strPDFName = "c.Value_" & "SalesReport_" & ".pdf"
      If bTest = False Then
         strSendTo = c.Offset(0, 300).Value
       wsR.ExportAsFixedFormat _
         Type:=xlTypePDF, _
         Filename:=strSavePath & strPDFName, _
         Quality:=xlQualityStandard, _
         IncludeDocProperties:=True, _
         IgnorePrintAreas:=False, _
         OpenAfterPublish:=False
      strMsg = "Could not start mail process for " & c.Value
       With OutMail
           .To = strSendTo
           .CC = ""
           .BCC = ""
           .Subject = strSubj
           .Body = strBody
           .Attachments.Add strSavePath & strPDFName
           .Send
       On Error GoTo 0
   Next c
   wsM.Activate
   MsgBox "Emails have been sent"
exitHandler:
   Set OutMail = Nothing
   Set OutApp = Nothing
   Set wsM = Nothing
   Set wsS = Nothing
   Set wsL = Nothing
   Set wsR = Nothing
   Set rngL = Nothing
   Set rngSN = Nothing
   Set rngPath = Nothing
   Exit Sub
errHandler:
   MsgBox strMsg
   Resume exitHandler
Function DoesPathExist(myPath As String) As Boolean
    Dim TestStr As String
    If Right(myPath, 1) <> "\" Then
        myPath = myPath & "\"
    TestStr = ""
    TestStr = Dir(myPath & "nul")
    On Error GoTo 0
    DoesPathExist = CBool(TestStr <> "")
End Function
Sub GetFolderFilesPDF()
Set rngPath = wksSet.Range("rngPath")
     With Application.FileDialog(msoFileDialogFolderPicker)
        .AllowMultiSelect = False
        .Show
        If .SelectedItems.Count > 0 Then
            rngPath.Value = .SelectedItems(1)
Sub TestOutlook()
    Dim oOutlook As Object
    Set oOutlook = GetObject(, "Outlook.Application")
    On Error GoTo 0
    If oOutlook Is Nothing Then
        'Call NameOfYourMailMacro
