VBA Code for Clear Contents in different sheets containing different rows and columns
Hi All,
For clearing contents I had written a vba code but I had written separately for all the sheets as because different sheet contains different rows & column.
Is there any way ( vba code ) where I can run all of them together and my contents gets cleared.
Please help.
ThanksRaj
  • qrt.xlsm
Change code to this. When you run macro - you will only see "DELETE"
Private Sub DELETE1()
Worksheets("suven").Range("g2:G117").ClearContents
Private Sub DELETE2()
Worksheets("suman").Range("f2:f197").ClearContents
Private Sub DELETE3()
Worksheets("raj").Range("e2:e100").ClearContents
Sub DELETE()
Call DELETE1
Call DELETE2
Call DELETE3
Hi Chirayu
Thanks a lot.
Just one question I am having 60 sheets so for all the sheets I need to write the private sub functions and then call delete for all the sheets.
or is there any other way to do it.
Kindly suggest.
Thanks Raj
Delete all the code & use this instead
Sub ClearCols()
Dim LstRow As String
Dim ws As Worksheet
Dim EndCol As String
For Each ws In ActiveWorkbook.Worksheets
    ws.Select
    LstRow = Cells(Rows.Count, "A").End(xlUp).Row
    Range("A1").End(xlToRight).Offset(1, 0).Select
    EndCol = Split(ActiveCell.Address, "$")(1)
    Range(EndCol & "2:" & EndCol & LstRow).ClearContents
Instead of select, you can do it like this.
Sub DelLastCol()
Dim ws As Worksheet
Dim lRow As Long
For Each ws In ThisWorkbook.Worksheets
    lRow = ws.Cells(Rows.Count, 1).End(xlUp).Row
    ws.UsedRange.End(xlToRight).Resize(lRow, 1).Offset(1, 0).ClearContents
Next ws
Hi !
Another way just respecting TBTO rule :​
Sub ClearLastColumn()
         Dim Ws As Worksheet
    For Each Ws In ThisWorkbook.Worksheets
        With Ws.UsedRange.Columns
            .Item(.Count).Offset(1).ClearContents
rush2rajen, reminder :
This applies for any post that helped you …
