Morning all,
I am using the below code to create multiple sheets from a data sheet. Currently when i run the code it asks if i want to save them and i then have to select a folder for them to go into.
I would like to remove the question and get the code to automatically save the workbooks it creates within a predefined folder then within another folder that it will create that is named by the contents of a cell in the data sheet. Additionally it would be great if i could add a predefined password to the workbooks it saves. This would be set within the code so no need to type it in each time.
Is there anyone that can point me in the right direction to edit the code to do the above? I managed to edit it to save in a predefined folder but not to create the new folder. The code below is the original without this edit as my edits may not have been the cleanest.
Many thanks for your help.
Sub FillOutindividualschedules()
'From Sheet1 data fill out template on sheet2 and save
'each sheet as its own file.
Dim LastRw As Long, Rw As Long, Cnt As Long
Dim dSht As Worksheet, tSht As Worksheet
Dim MakeBooks As Boolean, SavePath As String
Application.ScreenUpdating = False 'speed up macro execution
Application.DisplayAlerts = False 'no alerts, default answers used
Set dSht = Sheets("Calculations") 'sheet with data on it starting in row2
Set tSht = Sheets("ScheduleTemplate") 'sheet to copy and fill out
'Option to create separate workbooks
MakeBooks = MsgBox("Create separate workbooks?" & vbLf & vbLf & _
"YES = template will be copied to separate workbooks." & vbLf & _
"NO = template will be copied to sheets within this same workbook", _
vbYesNo + vbQuestion) = vbYes
If MakeBooks Then 'select a folder for the new workbooks
MsgBox "Please select a destination for the new workbooks"
Do
With Application.FileDialog(msoFileDialogFolderPicker)
.AllowMultiSelect = False
.Show
If .SelectedItems.Count > 0 Then 'a folder was chosen
SavePath = .SelectedItems(1) & "\"
Exit Do
Else 'a folder was not chosen
If MsgBox("Do you wish to abort?", _
vbYesNo + vbQuestion) = vbYes Then Exit Sub
Loop
'Determine last row of data then loop through the rows one at a time
LastRw = dSht.Range("C" & Rows.Count).End(xlUp).Row
For Rw = 12 To LastRw
tSht.Copy After:=Worksheets(Worksheets.Count) 'copy the template
With ActiveSheet 'fill out the form
'edit these rows to fill out your form, add more as needed
.Name = dSht.Range("C" & Rw)
.Range("C9").Value = dSht.Range("A" & Rw).Value
.Range("C11").Value = dSht.Range("H" & Rw).Value
.Range("C12").Value = dSht.Range("G" & Rw).Value
.Range("C13").Value = dSht.Range("I" & Rw).Value
.Range("C14").Value = dSht.Range("K" & Rw).Value
.Range("C15").Value = dSht.Range("Q" & Rw).Value
.Range("C16").Value = dSht.Range("R" & Rw).Value
.Range("C17").Value = dSht.Range("L" & Rw).Value
.Range("C18").Value = dSht.Range("S" & Rw).Value
.Range("C19").Value = dSht.Range("V" & Rw).Value
.Range("C24").Value = dSht.Range("AC" & Rw).Value
.Range("D24").Value = dSht.Range("AB" & Rw).Value
.Range("C25").Value = dSht.Range("AD" & Rw).Value
.Range("D25").Value = dSht.Range("AB" & Rw).Value
.Range("C26").Value = dSht.Range("AE" & Rw).Value
.Range("D26").Value = dSht.Range("AB" & Rw).Value
.Range("C27").Value = dSht.Range("AF" & Rw).Value
.Range("C31").Value = dSht.Range("AH" & Rw).Value
.Range("C32").Value = dSht.Range("AK" & Rw).Value
.Range("C33").Value = dSht.Range("AO" & Rw).Value
.Range("C34").Value = dSht.Range("AQ" & Rw).Value
.Range("C35").Value = dSht.Range("AS" & Rw).Value
.Range("C43").Value = dSht.Range("M" & Rw).Value
.Range("D43").Value = dSht.Range("T" & Rw).Value
.Range("C44").Value = dSht.Range("N" & Rw).Value
.Range("D44").Value = dSht.Range("T" & Rw).Value
.Range("C45").Value = dSht.Range("O" & Rw).Value
.Range("D45").Value = dSht.Range("T" & Rw).Value
.Range("B51").Value = dSht.Range("Y" & Rw).Value
.Range("C51").Value = dSht.Range("Z" & Rw).Value
.Range("D51").Value = dSht.Range("AA" & Rw).Value
If MakeBooks Then 'if making separate workbooks from filled out form
ActiveSheet.Move
ActiveWorkbook.Saveas SavePath & Range("C9").Value, xlNormal
ActiveWorkbook.Close False
Cnt = Cnt + 1
Next Rw
dSht.Activate
If MakeBooks Then
MsgBox "Workbooks created: " & Cnt
MsgBox "Worksheets created: " & Cnt
