Good Day Everyone,
Im looking for a clean VBA macro to look at two different sheets and combine them based on unique identifiers (staff IDs). I've recorded and cleaned a macro that does some copy pasting and then using vlookup to pull in the data (Code Provided below).
Im looking for a way to do this a little more efficiently as I will be looking at thousands of rows of data and Vlookups are quite bulky.
Does anyone have a better alternative to vlookups?
Sub Combine()
' Combine Macro
Sheets("Basic").Select
Range("A1:AM365").Select
Selection.Copy
Sheets("Sheet3").Select
Range("A2").Select
ActiveSheet.Paste
Selection.Columns.AutoFit
Sheets("Calibration").Select
Range("B1:AM365").Select
Selection.Copy
Selection.End(xlToRight).Select
Range("AN2").Select
ActiveSheet.Paste
Range("AN1").Select
ActiveCell.FormulaR1C1 = "=1"
Range("AO1").Select
ActiveCell.FormulaR1C1 = "=RC[-1]+2"
Range("AO1").Select
ActiveCell.FormulaR1C1 = "=RC[-1]+1"
Range("AO1").Select
ActiveWindow.SmallScroll ToRight:=2
Selection.AutoFill Destination:=Range("AO1:BH1"), Type:=xlFillDefault
Range("AO1:BH1").Select
Range("AN3").Select
ActiveCell.FormulaR1C1 = _
"=VLOOKUP(RC1,Calibration!R2C1:R365C22,Sheet3!R[-2]C,FALSE)"
Range("AN1").Select
ActiveCell.FormulaR1C1 = "2"
Range("AN3").Select
Selection.AutoFill Destination:=Range("AN3:AN366")
Range("AN3:AN366").Select
Range("AN4").Select
Range("AN3").Select
"=VLOOKUP(RC1,Calibration!R2C1:R365C22,Sheet3!R1C40,FALSE)"
Range("AN3").Select
"=VLOOKUP(RC1,Calibration!R2C1:R365C22,Sheet3!R[-2]C40,FALSE)"
Range("AN3").Select
Range("AN3").Select
"=VLOOKUP(RC1,Calibration!R2C1:R365C22,Sheet3!R1C,FALSE)"
Range("AN3").Select
Selection.AutoFill Destination:=Range("AN3:AN4"), Type:=xlFillDefault
Range("AN3:AN4").Select
Range("AN4").Select
Selection.AutoFill Destination:=Range("AN4:AN366")
Range("AN4:AN366").Select
Range("AN3").Select
Selection.Copy
Range("AO3").Select
ActiveSheet.Paste
Selection.AutoFill Destination:=Range("AO3:AO366")
Range("AO3:AO366").Select
Range("AO3").Select
Selection.Copy
Selection.AutoFill Destination:=Range("AO3:BH3"), Type:=xlFillDefault
Range("AO3:BH3").Select
Selection.AutoFill Destination:=Range("AO3:BH365"), Type:=xlFillDefault
Range("AO3:BH365").Select
Range("A2").Select
Range(Selection, Selection.End(xlToRight)).Select
Range("A1").Select
