Using VBA to Auto refresh an advanced Filter
Andrew D
Hi All,
I was wondering if anyone can help with the following:
I have set up an advanced filter in Excel 2007 to filter data from a master spreadsheet (Download) into seperate sheet (MI)
The Advanced Filter details look like this:
List Range: Download!$A$1:$AK$100
Criteria range: MI!Criteria
Copy to: MI!Extract
Is there a way to use VBA to auto refresh this filter if new data is added into the Download sheet?
I have very little VBA knowledge so any advice woul be great.
Thanks,
Andrew
You'll probably want to limit how often this macro gets fired. Currently, it goes off if ANYTHING gets changed, but here's the layout:
[pre]
'This code will get fired if ANYTHING gets changed
'may need to add some additional criteria to limit this
'Advanced filter code
Worksheets("Download").Range("$A$1:$AK$100").AdvancedFilter Action:=xlFilterCopy, _
CriteriaRange:=Worksheets("MI").Range("Criteria"), _
CopyToRange:=Worksheets("MI").Range("Extract"), Unique:=False
[/pre]
