Using Right Function
parth007
I have one excel sheet which have data in Column "A"
Now need Vba code to only write last 3 letters of column "a" in column"B"
Below is the code
ActiveSheet.Range("B2:B5000") = Right(ActiveSheet.Range("A2"), 3)
Problem here is that column "A" may have n number of records in it... and the code only works for one single column..
any suggestion..
Attached is sample file.
Sorry Team members i got theanswer...
Dim SourceRange As Range, DestinationRange As Range, i As Integer
    'Define our source range as A1:A10 of Sheet1
    Set SourceRange = ActiveSheet.Range("A1:A5000")
    'Define our target range where we will print.
    'Note that this is expected to be of same shape as source
    Set DestinationRange = ActiveSheet.Range("B1:B5000")
    'Iterate through each source cell and print left 2 bits in target cell
    For i = 1 To SourceRange.Count
        DestinationRange(i, 1).Value = Right(SourceRange(i, 1).Value, 3)
A very bad idea to use a loop for this kind of stuff ‼ :confused:
Worksheet functions are more efficient !​
    With Sheet1.Cells(1).CurrentRegion.Columns(2)
        With .Cells(2).Resize(.Rows.Count - 1)
            .FormulaR1C1 = "=RIGHT(RC[-1],3)"
                .Formula = .Value
Marc, actually me a Sql server DBA, but we are dependent on the data from excel which we receive from fellow members post we upload in SQL Database & work on it.. Unfortunatley the team is not available to provide the structured Excel data to us.. so as i have little knowledge of VB i am asked to streamline all reportings so that My original profile (SQL DBA/ Developer) will not face any delay in work..
So the best i could think is to take helpo from Expert in forums... :(
