using different lookup tables for males and females
cataholic
Hi everyone,
This is my first post and I should say that I have never had any excel training, I have just picked it up as I go along, primarily from reading this forum. Unfortunately this means thee are some pretty big gaps in my knowledge, so there are complex things I can do and simple ones I can't.
I am trying to create a spreadsheet that will automatically calculate hearing loss by age and sex and I have got the spreadsheet working perfectly for men, using the following code
=HLOOKUP(K7,'MTables'!C6:O9,IF(K8='MTables'!B7,2,IF(K8='MTables'!B8,3,4)))
MTables are values for men sorted by various factors. I also have similar tables for women called FTables
what I want to do now is add a cell where I input the sex and select the Table accordingly. I have tried doing it with IF statements but all of them result in a ridiculously long argument and don't work.
I am sure someone out there can see a simple way out of this and I am looking forward to slapping my forehead and saying 'D'OH!
Thanks in advance to everyone.
Welcome to the forums!
Try this formula:
=HLOOKUP(K7,INDIRECT(A2&"Tables!C6:O9"),IF(K8=INDIRECT(A2&"Tables!B7"),2,IF(K8=INDIRECT(A2&"Tables!B8"),3,4)))
Where all the A2 references in bold represent the target cell where you will simply enter M or F to toggle between the data sources.
Try this formula:
Thanks Eibi-this just gives a REF error. I have googled INDIRECT and see how this works but don't see how the code distinguishes between MTables and FTables I will upload the spreadsheet in my answer to Somendra in the hope this will assist.
Many thanks
Can you upload a sample file with some dummy data.
Hi Somendra,
Here is the sample file. I have created a dropdown for male & female, but as you can see, it only selects the male data at present.
Kind Regards,
  • draft audio.xlsx
See this file, I had given the formula on Calculation sheet K9. If it is working as per your need try to put the formula with change ranges in other cells.
  • draft audio.xlsx
Hi Somendra.
Your formula works perfectly on K9. I will try putting it in other cells, but can you explain to me why the formula refers to 'Tables!' when the relevant tables are called MTables and FTables respectively? Until I understand this I cant see why your formula works.
Many thanks,
There is a LEFT function also which will give Either M or F from drop down selection. Which is than concatenated with Tables to make sheet name for ref.
