Using Array Formulas for Auto Formatted Tables
Excel Pro
I have an auto formatted table with dates, client names and amounts. I need to do the sum of amount by months to prepare a chart. I am using this formula but it is giving the sum of all rows instead of giving sum for only the month of January.
{=SUM(IF(MONTH(Table1[Date]=1),Table1[Amount],))}
This same formula works well with normal range of cells.
{=SUM(IF(MONTH($C$10:$C$14)=1,$D$10:$D$14,0))}
How can I calculate the total amount for each month using data from auto formatted table?
Thanks for help.
First , I am not sure whether your original formula in the worksheet is the same as what you have posted here , but your posted formula has probably a typo ; it should actually be :
=SUM(IF(MONTH(Table1[Date])=1,Table1[Amount],))
