Using an IF statement for a filter [SOLVED]
jassybun
Hey guys! How has everyone been?
I am using a filter, but I want to show at the top (above filter) what I am filtering.
I made these functions, but unfortunately they include the hidden rows, which obviously doesn't help. How can I only show what I am filtering? The filter being used is the P column.
Cell A1=IF(ISNA(MATCH(6001,P8:P500,0)),"","6001")
Cell A2=IF(ISNA(MATCH(6002,P8:P18,0)),"","6002")
Cell A3==IF(ISNA(MATCH(6006,P8:P18,0)),"","6006")
If only one of those numbers will be shown, you could do:
=IF(SUBTOTAL(103,P8:P500)=ROWS(P5:P500),"",SUBTOTAL(101,P8:P500))
What's it doing? We first check to see if the number of visible cells equals total number of cells in range. If it does, there's no filter, so display "". If we do have a filter, and agian, making BIG ASSUMPTION that only 1 number is chosen, we display the average of visible cells. Since it's only 1 visible number, the average = that number.
I would want to show whichever ones are being filtered..like a distinct value.
None filtered would show this:
6001
6002
6006
(filter)Area.....Amount
........6001.....4
........6001.....10
........6002.....1
........6006.....10
Should you filter only 6001, it would look like this:
6001
(filter)Area......Amount
........6001......4
........6001......10
Is that possible?
Try this :
=IF(SUBTOTAL(101,$P$8:$P$500)<>SUBTOTAL(104,$P$8:$P$500),"",SUBTOTAL(104,$P$8:$P$500))
This assumes that the Area item is a numeric value , not text.
@jassybun
Yes, I thought that's what my formula did. Was it not working like you wanted? I suppose you could change the "" to be "All" like this:
=IF(SUBTOTAL(103,P8:P500)=ROWS(P5:P500),"No filter",SUBTOTAL(101,P8:P500))
JassyB
This is a tricky one for formula to handle because when you need to return multiple instances of the filtered list a formula is going to struggle. I could be wrong on that but I can't see how it can return all instances in one formula.
I can't offere an addition for anyone looking to return numbers or text. Put a volitile formula in Cell P1 say Today()
Put the following in the worksheet where you want this to fire from ie sheet1.
[pre]
Private Sub Worksheet_Calculate()
[P2] = Range("P8:P800").SpecialCells(12).Cells(1, 1).Value
[/pre]
It will give you a single filtered result be it numbers or text.
If you want all filtered results then the following will give you exactly what I understand your needs to be.
http://j-walk.com/ss/excel/usertips/tip044.htm
Gave it a test and it seems to go well.
Take care
Smallman
ps. Naranyan the code tip you gave me works a treat. Thanks again for the screenshot.
Smallman - thanks for that link - I have never heard of that site but that article is exactly what I was talking about! Thank you Luke and Narayank as well. I am using the equation supplied and it is working :)
You guys are awesome.
