Using a formula to sort two columns
brightyoyo
Hi the formula works great when I manually use it , but I would like to use it in a macro where it sorts column B as well.
This is part of the macro
Dim F As Range
'Add Formula
For Each F In Range("A1:A" & Range("A" & Rows.Count).End(xlUp).Row)
F.Offset(, 3).FormulaArray = _
"=INDEX(List, MATCH(SMALL(COUNTIF(List, ""<""&List), ROW(R)), COUNTIF(List, ""<""&List), 0))"
Next F
Hi, brightyoyo!
It should be like this:
[pre]
"=INDEX(List, MATCH(SMALL(COUNTIF(List, """"<""""&List), ROW(R)), COUNTIF(List, """"<""""&List), 0))"
[/pre]
Didn't check if the original worked in a worksheet, but if it does this is the equivalent to set it by VBA code.
Regards!
Hi That just copied the first cell and then copied it down the column. What I am looking for is to sort Column A and B according to Column A. I would like to do this with a macro. Here is a sample
https://www.dropbox.com/sh/67unlewr92vgm3z/XAGscYaB7G
Hi, brightyoyo!
That just was the answer to your original request. I'd try to check the file later.
Regards!
