userform multipage problem
mahaveer
i have a userform with multipage1. On multipage1 there are 3 pages.
1 page = Creation
2 page = Suppliers (visible = false)
3 page = Inventory (visible = false)
on 1 page i have two command button.
1 command button = Add suppliers
2 command button = Add Inventory
the command on 1st command button is following:
Multipage1("page2").visible = true
Multipage1("Page2").enabled = true
Multipage1("Page3").visible = false
the command on 2nd command button is following:
Multipage1("page3").visible = true
Multipage1("Page3").enabled = true
Multipage1("Page2").visible = false
my Problem:
when my userform initialize then "creation" page automatically open only
now when i press the 1st command button i.e. add supplier then 2nd page "Suppliers" is visible but "supplier" page not open automatically still i m on creation page only why? is there any way to open the 2nd page from 1st command button on page1.
Hi Mahaveer ,
Check out these two links :
1. http://support.microsoft.com/kb/155374
2. http://www.excelforum.com/excel-programming-vba-macros/349639-userform-multipage-select-a-tab.html
According to them , you need to use something like :
Multipage1.Value = 0 to select the first page
Multipage1.Value = 1 to select the second page
Multipage1.Value = 2 to select the third page.
answer:
I have to add one more line in 1st command button and 2nd command button at the end i.e.
multipage1.value = 1
now some one can tell me as i have got my answer of the above query that how to remove this question from here for save the time of all experts.
Thanks Narayank dear
i followed you trick but till i could not see you post
but thanks dear
your answer is best answer.
and thanks you to dear for your sgmpatnaik valuable time.
