Userform Input data to Next blank Row for each data entry
Korekurd
were Textbox1 = Employee Number
and Textbox2 = Line Chooses
VBA Code:
>>> use code - tags <<<
Dim EmpID$, dDate$, Rg As Range, i&, x&
EmpID = TextBox1.Value
If TextBox1.Value = "" Or TextBox2.Value = "" Then
   MsgBox "PLEASE FILL IN EMPLOYEE NUMBER & ENTER BID LINE CHOOSES ... ", vbExclamation: Exit Sub
If Not IsNumeric(EmpID) Then MsgBox "INVALID EMPLOYEE NUMBER ENTER NUMBER WITHOUT THE E", vbExclamation: Exit Sub
With Sheets("SHIFT BIDS")
   For i = 1 To 2
      dDate = IIf(i = 1, TextBox1.Value, TextBox2.Value)
      If Len(dDate) > 0 Then
         Set Rg = .Columns(1).Find(EmpID, lookat:=xlWhole)
         If Rg Is Nothing Then
            MsgBox "EMPLOYEE NUMBER DOES NOT EXIST PLEASE TRY AGAIN", vbExclamation: Exit Sub
            Set Rg = IIf(i = 1, ThisWorkbook.Sheets("Bid Data").Cells(, "D").Resize(500), ThisWorkbook.Sheets("Bid Data").Cells(, "E").Resize(, 500))
            If InStr(dDate, ".") Then
               For x = 0 To UBound(Split(dDate, "."))
                  Rg.Find("", after:=Rg.Cells(Rg.Count)) = Split(dDate, ".")(x)
               Rg.Find("", after:=Rg.Cells(Rg.Count)) = dDate
TextBox1.Value = ""
TextBox2.Value = ""
TextBox1.SetFocus
[code]
when I type in 9324 in Textbox1 and 1.2.3 and textbox2 and press enter on the first set of data then type 6475 textbox1 and 10.9.8 in textbox2 and press enter for the second set of data The results I get with the above code is as follows:
[TABLE]
[TR]
[TH]D[/TH]
[TH]E[/TH]
[TH]F[/TH]
[TH]G[/TH]
[TH]H[/TH]
[TH]I[/TH]
[TH]J[/TH]
[/TR]
[TR]
[TD]9324[/TD]
[TD]1[/TD]
[TD]2[/TD]
[TD]3[/TD]
[TD]10[/TD]
[TD]9[/TD]
[TD]8[/TD]
[/TR]
[TR]
[TD]6475[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
What I need done is the second data of textbox2 to go with second data of textbox1 so results should be:
[TABLE]
[TR]
[TH]D[/TH]
[TH]E[/TH]
[TH]F[/TH]
[TH]G[/TH]
[TH]H[/TH]
[TH]I[/TH]
[TH]J[/TH]
[/TR]
[TR]
[TD]9324[/TD]
[TD]1[/TD]
[TD]2[/TD]
[TD]3[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]6475[/TD]
[TD]10[/TD]
[TD]9[/TD]
[TD]8[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
any help is greatly appreciated.
I tried to sort out your macro code layout. If you original code in your workbook is not indented as it should be, that is the cause of your
problems. Without indenting it is very easy to lose track of the IF/END IF, FOR/NEXT, etc. etc.
This is as far as I got with trying to straighten things out :
        For i = 1 To 2
TextBox1.Value = ""
TextBox2.Value = ""
TextBox1.SetFocus
If you original code is properly indented, please post it here for review.
Here is another method of writing data to rows :
Private Sub btnCancel_Click()
    Unload Me
Private Sub btnOK_Click()
    Dim ws As Worksheet
    Set ws = ActiveSheet
    Dim newRow As Long
    newRow = Application.WorksheetFunction.CountA(ws.Range("A:A")) + 1
    'The next two lines can be expanded as many times as needed for all the entry fields in your project
    ws.Cells(newRow, 1).Value = Me.txtFirstName.Value
    ws.Cells(newRow, 2).Value = Me.txtSurname.Value
    Selection.EntireRow.Delete
With just a small amount of editing, you can utilize it for your project.
  • Simple Database.xlsm
