Hi All,
Sadly got myself in a bit of a mess... I am creating a dashboard and in the process I have created numerous sheets calling a finite number of Pivot Tables. The Pivot Tables are very large and I think that in my excitement I have created at least a couple of Pivot Tables that are no longer referenced so hence for performance/memory reasons I need to remove them. The problem is that I am not sure which ones they are ?!!
Is there an easy way of tracing calls to GetPivotData function within a workbook and ascertaining the name of the PivotTables referenced on each and every worksheet ?
Initially I would like to loop through the workbook and report references to Pivot Tables for each Sheet and then perhaps thereafter list the cell references making the calls.
Also as a by-the-by - is there any truth in what I read somewhere, that copying a PivotTable and then changing its attributes uses less resources than simply creating a new PivotTable from scratch each time ? Something to do with shared cache perhaps ?
I am relatively new to VBA and loving it...
Any assistance gratefully received
