Title should read Dynamically adjust X axis time scale with vba
dnessim
I guess the VBA forum would be a better place to ask this one?
First, Is it true that a regular line chart cant scale the Y axis in hours? so we should use a scater plot?
Here is my real question,
My hospital takes temp and humidity readings every 30 mins for 11 Operating rooms. This data is saved to a big Excel file.
I have a procedure that creates a new workbook with worksheets and charts for each room. From a user form my user can enter a start date to end date .
So each worksheet has a chart on it , the X axis has the time/date and the Y axis has the Humidity reading.
If the user selects 1 day of data , then my “major unit” scale would be 1/24 = .0416666
So it takes the 48 data points and plots 24 of them 1 hour apart. This works great.
If my user selects a 30 day range then too many points are plotted on the date axis, the correct number would be 1 so that it plots 30 points 1 day apart.
What I want to be able to do is come up with the math that would let it be adjusted dynamically in my program,
Anybody know how I could do this?
I am also assuming that the only chart that would work for this is a xlXYScatterLinesNoMarkers
Here is a snippet of the code If I always wanted it set for 1 day (plot every hour) then
Myval = 1/24 or .0416666
'Create a chart on each new worksheet
Set hchart = Worksheets(roomname).Shapes.AddChart.Chart
hchart.SetSourceData Source:=HRange
hchart.ChartType = xlXYScatterLinesNoMarkers
hchart.SetElement (msoElementLegendBottom)
hchart.Axes(xlCategory).Select
hchart.Axes(xlCategory).MinimumScale = MinScaleValue
hchart.Axes(xlCategory).MaximumScale = MaxScaleValue
'displays dates in the x axis by hour increments, not exact
hchart.Axes(xlCategory).MajorUnit = myval
'Hchart.Axes(xlCategory).MinorUnit = .02
hchart.Axes(xlValue).MinimumScale = 10
hchart.Axes(xlValue).MaximumScale = 70
Thanks,
Dave
