Text Box Print Issue
juanito
Hi -
I have a simple report with commentary below in a text box which is print-enabled.
I tell Excel to print the whole sheet, center horizontally, sizing to one sheet landscape and so on - all pretty elementary.
Problem is, the report isn't centered horizontally - it's forced to the left so far that the first column is actually truncated.
I had a look around and this may be a bug - does anybody have any further info or suggestions?
Thanks, Juanito
Good day juanito
Have you tried to print by selection and adjust the print columns to suit.
Hi -
Yes that works - the issue is that the sheet is part of a large reporting deck, so I can't just print off with print by selection? I want to be able to print the whole thing in one go.
Even odder, is that if I print to pdf the sheet looks fine... wow.
- Juanito
Hi, juanito!
Consider uploading a sample file? Give a look at the second green sticky post at this forums main page for uploading guidelines.
Regards!
