Syntax Problem
ravikumar00008
HI,
This is the query i am using to update the records.
But when i am executing,getting sql syntax error.
Please correct the syntax of the query.
[pre]
sSQL = "UPDATE TblTest " & _
"set [Month] = '" & SplitMonth & "' , [Year] = '" & SplitYear & "' , [Protocol#] = '" & ColA & "'" & _
" [Project Name]= '" & ColB & "' , [Project Coord]= '" & ColC & "' , [Lot#]= '" & ColD & "'" & _
" [Date Rec'd]= '" & ColE & "' , [Date ready to measure]= '" & ColF & "' , [Date Measured]= '" & ColG & "'" & _
" [Qty of Lenses Measured]= '" & ColH & "' , [BC]= '" & ColI & "' , [CT]= '" & ColJ & "'" & _
" [Power]= '" & ColK & "' , [Diameter]= '" & ColL & "' , [Lens Cross Sections]= '" & ColM & "'" & _
" [Qty of Lenses x-sectioned]= '" & ColN & "' , [Others]= '" & ColO & "' , [CompletionDate]= '" & ColP & "'" & _
" [Turn Around Time(# of Days)]= '" & ColQ & "'" & _
" Where [ID]  = '" & SqlID & "'"
[/pre]
Kumar
Hi, ravikumar00008!
Without the TblTest definition (fields and types) and without the variables definition (field, types and values), there's no much that can be done, except for missing commas after fields:
Protocol#, Lot#, [Date Measured], CT, [Lens Cross Sections], CompletionDate
Regards!
Hi SirJB7,
Thanks for the help.
yes the lack of commas is the problem.
here is the correct code.
[pre]
sSQL = "UPDATE TblLabParams " & _
"set [Month] = '" & SplitMonth & "' , [Year] = '" & SplitYear & "' , [Protocol] = '" & ColA & "'" & _
" ,[ProjectName]= '" & ColB & "' , [ProjectCoordinator]= '" & ColC & "' , [Lot]= '" & ColD & "'" & _
" ,[DateRecord]= '" & ColE & "' , [DateReadyToMeasure]= '" & ColF & "' , [DateMeasured]= '" & ColG & "'" & _
" ,[QtyOfLensMeasured]= '" & ColH & "' , [BC]= '" & ColI & "' , [CT]= '" & ColJ & "'" & _
" ,[Power]= '" & ColK & "' , [Diameter]= '" & ColL & "' , [LensCrossSections]= '" & ColM & "'" & _
" ,[QtyOfLensXSectioned]= '" & ColN & "' , [Others]= '" & ColO & "' , [CompletionDate]= '" & ColP & "'" & _
" ,[TurnAroundTime]= '" & ColQ & "'" & _
[/pre]
Kumar
Hi, ravikumar00008!
Glad you solved it. Thanks for your feedback and welcome back whenever needed or wanted.
Regards!
