Hey guys,
I have a problem with a file. Look at the attachment below. The sum function does not work. As I could do anything to solve it, I copied everything in Word Pad, then set the cells in General format, pasted them back. The sum function did not work, unles with the first column of numbers. I changed the format in number, the result was the same. I moved the cells and tried with left function, again the same result. Where is the problem according to you? The file is smal and I can make just a data entry on separate file but I want to manage with this one. By the way the file, which I have worked on and attached it for information in a copy of the original one.
Thanks,
Mariya
Thanks,
Mariya
