Solved: The Brackets were in the Wrong Place. Problem With If Function
Status
Not open for further replies.
I have three individual Ifs, that all work successfully on their own
IF(E3="Better Ball",MAX(N9,Q9,T9,W9))
IF(E3="Three Man Am-Am",SUM(MAX((N9,Q9,T9,W9),{1}))+SUM(MAX((N9,Q9,T9,W9),{2})))
IF(E3="Four Man Am-Am",SUM(MAX((N9,Q9,T9,W9),{1}))+SUM(MAX((N9,Q9,T9,W9),{2})))
If I put them together like this: IF(E3="Better Ball",MAX(N9,Q9,T9,W9),IF(E3="Three Man Am-Am",SUM(MAX((N9,Q9,T9,W9),{1}))+SUM(MAX((N9,Q9,T9,W9),{2}))),IF(E3="Four Man Am-Am",SUM(MAX((N9,Q9,T9,W9),{1})+SUM(MAX((N9,Q9,T9,W9),{2}))))), N9) I get a VALUE error, I have tried this as an array function too.
What I am trying to get is: If E is "Better Ball" the maximumof the four cells, if it either of the others, the highest two values, otherwise just the value from N9
Certificates!
Your thread's title starts with word Solved.
... that should mean - this thread is ... solved...
But still You're writing What I am trying to get is...
What is Your point?
Status
